Don't usually complain about tight but......
Old 08-05-2009, 05:16 PM
brettnbama's Avatar
brettnbama
brettnbama is offline
Default Don't usually complain about tight but......
Well, here's the deal.....I have worn out two pairs of Doc Marten's riding, so I decided to go ahead and drop the coin on a pair of riding boots. They are thicker than my Docs and I can't get the toe under the shifter. Good thing didn't take off the heel shifter. Well, I took the bolt all the way out of the toe shifter and couldn't get it to budge at all. I did not remove the heel shifter, I figured that it being on there shouldn't make a difference in wether or not the it could move....what's the trick?
Old 08-05-2009, 05:19 PM
albertasaurus's Avatar
albertasaurus
albertasaurus is offline
Isn't the heel shifter on the outside of the shaft? You'll have to remove the heel shifter, then the toe shifter, then rotate the toe shifter up a spline or two, then re-assemble.
Old 08-05-2009, 05:20 PM
cuda67bnl's Avatar
cuda67bnl
cuda67bnl is offline
Since there's teeth on the shaft and inside the shifter, I'm fairly certain you'll need to pull it off to adjust it. Remove the heel shifter, then the toe shifter. If it doesn't want to budge, tap a small flat bladed screwdriver into the slit. It'll spread the slit enough so that the shifter will budge.
Old 08-05-2009, 05:28 PM
Texas Fat Boy's Avatar
Texas Fat Boy
Texas Fat Boy is offline
What those two guys said...........and how do you wear out two sets of boots anyway?
Old 08-05-2009, 05:46 PM
VTwin-Goodies's Avatar
VTwin-Goodies
VTwin-Goodies is offline
Sponsor
Received 1,949 Likes on 1,933 Posts
You need to pull both heel and toe shifter off and replace a spline or two higher. I ahd the same problem with my Doc's as they have steel toes.
__________________
Old 08-05-2009, 05:49 PM
brettnbama's Avatar
brettnbama
I'm not sure, they aren't completely gone, but the front of the left sole is worn way down. I don't know how, I don't drag my feet or anything
Old 08-05-2009, 05:54 PM
CndUltra95's Avatar
CndUltra95
CndUltra95 is offline
Dragin his feet at Stop Lights maybe???
Rob
Old 08-05-2009, 05:58 PM
Maxcustody's Avatar
Maxcustody
Maxcustody is offline
That is why I love this site. I was at the dealer on Sunday and found a pair of new boots 50% off. Couldn't pass them up so I bought them. However I have the same problem now. So you are saying you can adjust the toe shifter? That is the only one I have on, the rear was already removed. Thanks.
Old 08-05-2009, 06:06 PM
cuda67bnl's Avatar
cuda67bnl
Yep. You can point it straight up in the air if you so choose.
Old 08-05-2009, 06:07 PM
brettnbama's Avatar
brettnbama
yep, I remember some guys saying they couldn't get them off, mine slid right off, got them adjusted and tightened back up in about 5 minutes....took longer to get the tools. Thanks guys.....
Quick Reply: Don't usually complain about tight but......
