Don't usually complain about tight but......
Old 08-05-2009, 06:27 PM
IBHarley's Avatar
IBHarley
IBHarley is offline
if you have room on the shift bar loosen the nuts and rotate the bar it will raise the toe shift
Old 08-05-2009, 06:48 PM
Maxcustody's Avatar
Maxcustody
Maxcustody is offline
Just got mine down too. Like Brett said took longer to get the tools. Thanks.
Old 08-05-2009, 07:23 PM
brettnbama's Avatar
brettnbama
brettnbama is offline
One last question, I used a 3/8" drive rachet and hex head socket to put the bolts back in, do you think you can tighten it so much as to hurt anything? I would imagine that the shaft is probably hardened steel..........
Old 08-05-2009, 07:38 PM
Estil's Avatar
Estil
Estil is offline
Gotta take the heal shifter off and then the toe shifter. Easy to adjust.....shouldn't talk but a few minutes.
Old 08-05-2009, 07:43 PM
DGlide04's Avatar
DGlide04
DGlide04 is offline
Use a little blue locktite and tighten the bolts down. No need to gorilla them down.
Old 08-05-2009, 07:52 PM
brettnbama's Avatar
brettnbama
roger, used blue loctite, didn't gorilla them, maybe chimp, but not gorilla
Old 08-05-2009, 08:47 PM
stamper5498's Avatar
stamper5498
stamper5498 is offline
Talking
If you don't tighten it good and use loctite the heel shifter will fall off at some point and time.
Ask me how i know
Old 08-05-2009, 10:28 PM
jberg's Avatar
jberg
jberg is offline
Use blue Loctite on the pinch bolts and a tiny bit on the splines. Eliminates the possibility of the shifters rattling. Also, as stated above, a twist of the shift rod will help to fine tune the height of the shift pegs if you're not happy with the position of the next spline.
Old 08-06-2009, 08:09 AM
skratch's Avatar
skratch
skratch is offline
Received 4,359 Likes on 2,537 Posts
yeah, i'd like to know how you wore out not one, but 2 sets of docs? i've been wearing mine for years, and they still have a ton of life left....
i like the idea of putting some loctite blue on the splines on the shaft. if you don't do something to alleviate some of the vibrating there, then the splines will get worn to the point that you will have to replace the whole shaft. good thing that its a cheap part and easy to replace.
Old 08-06-2009, 08:52 AM
dirtdobber's Avatar
dirtdobber
dirtdobber is offline
Depending on the bike there are 2 ways to adjust the shifter. 1 way affects both, toe and heel, the 2nd only adjust 1 or the other.
Removing the toe/heel is the way most do it. Slight adjustments can be made with the linkage, however when you have the toe and heel shifter it will raise 1 and lower the other.
I do not use the heel shifter so I removed it. I can make some adjustments in a min. or so. Just loosen the 2 jam nuts on the linkage. Turn the shaft. It has left and right hand threads. As you turn the shaft it will either go up or down.
In God we Trust
dd
Quick Reply: Don't usually complain about tight but......
