I find adjusting air shock pressure on my 09 Road King difficult. It goes way up easily and then when I bleed it out it goes down to nothing. Any similar experiences or is something wrong?
Please tell us you are not using an air compressor to add air to your shocks and then pushing in on the valve core with a small object to bleed air out....................
If so, just get the hd air pump and your problems will go away, unless you have already blown your seals from using an air compressor.
I used a home compressor with a regulator set to low pressure. Adjusted it to 10 lbs about a month ago and there is still 10 lbs in the system (air gauge check) which (I guess) means nothing blew since it's holding pressure. Going to go the pump route.
