V & H Monster Ovals
Old 08-04-2009, 07:33 PM
TennesseeEG's Avatar
TennesseeEG
TennesseeEG is offline
Default V & H Monster Ovals
I have the Monster Ovals on my '09 Streetglide. I like the sound, but I would like them to be a little louder. Has anyone modified, drilled, or punched a hole in the baffles? If so, how did they sound after the mod?
Thanks,
Old 08-04-2009, 07:52 PM
Scooter308's Avatar
Scooter308
Scooter308 is offline
Which way are your tips pointing?
I have heard if they are slash down the reflection off the ground gives you more noise.
Mine have always been slash up, have 3300 miles on them and love the sound.
rick's Avatar
rick
rick is offline
I had the MO's once had the same problem not enough sound or grunt.Sold them.Anyhow to my understanding they may be a little louder with duals,so they say.
Old 08-05-2009, 03:32 PM
cfmii11's Avatar
cfmii11
cfmii11 is offline
No - I like 'em the way they are and I have true duals.
Old 08-05-2009, 05:04 PM
davewear's Avatar
davewear
davewear is offline
how long have you had them? mine got a bit louder after a 1000 miles or so.... perfect now, wouldn't want any louder.
Old 08-05-2009, 06:10 PM
TexasVet's Avatar
TexasVet
TexasVet is offline
I've also put @ 1k miles on mine and they have gotten louder. I have TD's.
Old 08-05-2009, 08:29 PM
Ozoneman's Avatar
Ozoneman
Ozoneman is offline
Thanks,
If you want them a little louder, put true dual headers on your bike. That will kick it up a notch. It did on my bike.
Old 08-05-2009, 09:20 PM
papifun's Avatar
papifun
papifun is offline
ill traid u my V&H Ovals for ure Monsters ?
Old 08-05-2009, 09:55 PM
wrenchguy24's Avatar
wrenchguy24
wrenchguy24 is offline
I have true duals but my bike also has big bore kit with SE 203 cams!!!
I havent made to many long trips with it yet since I have done all this work but
The other day I took a 2 hour ride on interstate !!! I tell you I dont think I want them any louder!!!!
I did see a post a while back !!! A guy took his bike to get it dynoed !! When he got it back he said it seemed louder!!!! With further looking he found they punched holes
in the flat part of the inside of the muffler to get the sniffer in all the way!!
Well I was considering doing this to mine, but now im not sure!!!
Old 08-05-2009, 11:27 PM
TennesseeEG
Thanks for the feedback.
I have 7k miles on the bike, K & N filter, SE super pro tuner, dyno'd at 5k miles. MOs did get slightly louder with age, but no difference immediately after the dyno run.
The dyno results charted 75 HP and 83 ft lbs torque...I expected a higher torque measurement. AFR is good at 13:1 between 2.5K and 3.5k rpm.
This is a gain of 5 hp at the top end ( I will never realize it) and 3 ft lb torque over the base map loaded at the time of purchasing the bike. AFR read 13.5:1 baseline prior to tune.
If I had known how little gain/optimization the $400 dyno tune would yield, I would have saved my money. I used an indy that makes his living with the dyno...he has a good reputation.
Quick Reply: V & H Monster Ovals
