back to stock exhaust
First of al I have an 07 RG with K&N air filter, rine harts with fulsac true duel adapter. I would just like to know, could I go back to the stock exhaust with the true duel setup and K&N.
I Just would like to hear the change in sound. I think i need a bit of quiet for a little bit.
Thanks
Thanks
I take it you mean Fullsac's pipe kit which modifies the original system to true duals? I used one of them for a while on my old bike, to see if I liked true duals. When I gave the old lady a face-lift (well, an S&S 107 actually!) I fitted a set of new Samson true dual pipes, with S&S oval mufflers.
It's not the true duals that are making the noise, but the Rineharts! If you refit the original pipes you will find each muffler makes a slightly different sound, because the factory pipes send a different amount of exhaust down each side. Your true duals mean they make the same sound on both sides.
If you need a bit of quiet, I suggest you need some quieter mufflers. My S&S ovals are just great, nice and subtle, but if they are not quiet enough S&S makes additional inserts to reduce noise more.
An alternative, which is really cheap, is to try earplugs! Foam ones can be had from your local shooting shop, possibly bike shop. I use them on all my longer trips of more than a few miles.
So did you install the old Screamin Eagle slip ons that Supertrapp made or the newer quieter version that Harley sells now?
