Fuel line check valve
I have an 06 FLHXI and today it started to act up. A couple of times the engine just quit. She cranked fine, so electrical was ruled out. After fumbling around for I while I got it going by pushing up on the fuel line just as it comes out of the tank. It sounded like air was escaping and it fired right up. It quit a few more time but would fire right back up if I pushed up on the fuel line. Has anybody had problems with the fuel check valve coming out of the tank? I'm not sure if this is the problem or not?
Thanks
Thanks
Thanks
Thanks
There were some issues on the fuel line disconnects on a couple models where there was enuff pressure from the lower fitting and line going to the injection that it wore the ***** or the groove where the ***** sit when the line is locked in. Then what happened is the lower line dropped enuff to close the pistons in the upper and lower parts of the disconnect and no fuel can flow. The only other thing that could lead to this problem is just a manufacturing defect that leaves the piston in the upper part too short off the screw machine and thus a little wear from vibration again lets the bottom drop closing the fuel path. I have a lot of experience with these parts .. I used to work where they were made and build a couple machines to assemble and test them.. Pm me . I can possibly help.
This may be what happened to mine. It looked like the line was still connected but it would pull free with a downward tug (without pushing the locking collar up).
Well if you saw the way they are tested you you might think different on that.. We tested for piston height along with a vision system on the chrome parts while testing for leaks before shipping.. We also tested the same way although no vision system while assembling the lower black part. The chrome part is hand assembled.. Then after testing my wife checked some again (she works in QC) before shipping.. But stuff does happen.. Its interesting from the stand point that the parts were also tested at Delphi where they were shipped to (Mexico) before they made it to Harley and they wanted everything 100% reject free?.. Tell harley to make all the bikes 100% ... It would be cool to have had those parts to look at and I wonder if H/D asked for them back and returned them to Dexter Michigan for evaluation. Usually this was the case but not all the time..
