Notices
Tire pressure??
Old 08-02-2009, 04:40 PM
medic1555's Avatar
medic1555
medic1555 is offline
Default Tire pressure??
I just picked up an '08 SG today but the previous owner did not have the owners manual (gonna try to get one on eBay or from the dealer). In the mean time can someone tell me the proper tire pressure for front and rear (stock) tires? Thanking you in advance!
Old 08-02-2009, 04:45 PM
Johan96's Avatar
Johan96
Johan96 is offline
36 front 40 rear, but that is on the 09 models.
Old 08-02-2009, 04:55 PM
UltraEd's Avatar
UltraEd
UltraEd is offline
I run 36 front , 38-40 rear on my 08 Ultra
Old 08-02-2009, 04:57 PM
agent58's Avatar
agent58
agent58 is offline
I run 36 front and 40 rear on 08RK.
Old 08-02-2009, 05:02 PM
Ca.Fatlad's Avatar
Ca.Fatlad
Ca.Fatlad is offline
Post
Solo rider Front--36 psi Rear--36 psi
Rider and passenger Front--36 psi Rear--40 psi
Tire pressures (cold) 2008 Touring Models........(Owners Manual)
Old 08-02-2009, 05:07 PM
Jim Dawson's Avatar
Jim Dawson
Jim Dawson is offline
Right or wrong, I run 38 front and 40 rear no matter the load. I got 16,000 miles out of my first rear and had miles left. The front was nowhere near worn out but since I changed tire type (Elite 3) I changed them both together.
Old 08-02-2009, 05:42 PM
bwana1's Avatar
bwana1
bwana1 is offline
The max recommended tire preasure is written on every tire. That is the number to use.
Old 08-02-2009, 06:14 PM
paguy's Avatar
paguy
paguy is offline
Service manual will provide all info provided in the handbook and much more.
Old 08-02-2009, 06:24 PM
iambill's Avatar
iambill
iambill is offline
+1 just put new rear tires on my '08 ultra and the wifes'06 RK.
The guy at the shop said 40 rear and 38 front
Old 08-02-2009, 06:43 PM
KopperTop's Avatar
KopperTop
KopperTop is offline
Seriously, - do not use the numbers on the sidewall -- those are the max pressures the tire can take before it blows up. The manual has the right numbers and if you're running aftermarket tires, go to their site (e.g., Avon, Metzler) and look up the proper recommended pressures for your bike and load.
Quick Reply: Tire pressure??
