Detachable Tour pak for 09 Ultra questions.
Bought the kit and started looking at the kit and and not real sure about all the wiring for speakers and everything as far as where to put them. Im looking to put a street glide seat on it, but looks like all the wires will show. If anybody came up with or has a good idea for cleaning it up when the packs off, i would appreciate it. Thanks ahead of time.
Just wrapped up this install yesterday. A little time consuming but a relatively straightforward installation. The speaker wires and the tail that powers the trunk lights all coil up neatly right under the riders seat and totally out of sight. The two antenna leads are routed along the frame behind the bags and they too are out of sight. Another positive thing is with that big-*** "anchor" off of the bike and that weight at shoulder height way-in-the-back gone, the bike feels (better) and handles like a completely different motorcycle. After finishing I reversed it a couple of times and it takes less than ten minutes to go back and forth from tour pack to no tour pack.
I bought the kit for two reasons...one, for the relocation hardware and jumper for the CB antenna and two, that "just unplug the lights wiring inside the trunk and pull it thru the hole in the pack" stuff ain't quite that simple. The harness inside the trunk is too short to hang out without some "adjustment", the OEM connector is under the trunk liner, and the plugs in the kit are weather resistant.
