Harley Garage Door Opener
I made sure the wires are still attached to my garage door opener. And then I went through the programing set-up by pressing and holding the button on the H-D open, then turned the bike IGN and cylced the low/hi beam lights. The red light on the opener illuminated just like it is supposed to. After that when I cycle the low/hi beam lights, it still doesn't open my garage door. Anything else that I can check or anything that can be done to fix it?
Are you holding button down on receiver while operating headlights? LED on transmitter should be blinking while button is pressed on receiver.
The transmitter is installed inside the fairing. The LED is illuminated on the receiver. When I go through the programming process and push and hold the button on the receiver, it flashes. When I turn the IGN and cycle the lights the flashing LED on the receiver turns off until I let go of the button, then the LED is illuminated again.
Programming the Remote
Hi not to hi-jack the tread but in order to program the Genie with your Intellicode with Homelink you have to program once and the follow the setup the second time to make your homelink work. Read the directions for the Genie Intellicode to Homelink programming instructions. To answer your second question yes it will work with the Harley remote.
