PCV or TTS Mastertune
I have a 08 Ultra w/ a stock 96 and now that the 2010's are out I can go ahead and spend some $$$$ on my 08 Ultra. Don't see the need to upgrade right now. I would like to do the air mod, replace my Fullsac with V&H True headers and either add a PCV or a TTS Mastertune from Jamie at Fuel Moto. I'm thinking I would rather have Jamie map out the PCV and install everything on my own. If I went with the TTS I am not confident enough to set up and tune the TTS myself. So am I headed in the right direction or is one better than the other. Not looking for much other than cooling the engine down and letting it breathe better. If it gives it a little boost than all the better.
Thanks
Thanks
There are plenty of replies on both the TTS and the power commander. If you search you will find many comments, mostly positive on the PC V. If that is the route you choose, call Fuel Moto, their support is great. Don't consider saving a buck or two on used.
I did the PCV for more performance and cooling. I then added pipes (already done the SEAC) and the Autotunue. I am pretty happy with everything for now. I wasn't happy with the PCV until I changed pipes. 103 or not?
OBTW the PCV is pretty easy install, disconnect the battery, connect the cable to the ECM, reconnect, fire up, jump on smile...check gas mileage, ?, ...smile...continue to twist throttle...
