Engine check light
Engine check light
Stock 2007 Road King. Washed last night. Took out this morning and when excellerating check engine light came on. Back to my garage and found loose spark plug wire; corrected this. Went back out , bike running fine.
Problem: check engine light comes on for fuel injection. Goes out and then whether engine is running or not comes back on for a few seconds, then goes out and stays out while running.
Thinking maybe stock ECM squirely?
Hey guys, Sorry I didn't explain. by the time I finish this someone else will probably reply...
short version...
press and hold odometer rest button
turn ignition sw. to ignition (make sure kill switch is in run position)
"diag" appears in odometer window
press and release reset switch
PSStb appears
P should be flashing
press reset switch for more than 5 seconds
code is displayed (or none if no codes present)
press and release switch again to see if more codes are present.
if no more codes present "end" will appear
to clear DST's press an hold reset for more than 5 seconds
to exit without clearing, press and release the reset switch, turn off ignition
once you have the code, post it back up here, anyone with an electrical manual can look it up.
__________________
short version...
PSStb appears
__________________
