Road King std. looses tire pressure
Old 07-27-2009 | 11:43 PM
emwolb's Avatar
emwolb
post a thread cookiemech on the 82 degree valve stems please, lots of owners of the 09's could use the information. just a thought.
Old 07-28-2009 | 12:12 AM
bagman1's Avatar
bagman1
Get a spray bottle and make a soapy solution with water and dishwashing soap, make it extra soapy that way when you spray the entire wheel and tire the soap lays on thick and any leaks will start showing up as growing bubbles. Start with the max air psi, you will be able to sit there and watch the bubble grow, if nothing shows up rotate the wheel to expose the part that was under the fender.
Old 07-28-2009 | 02:53 AM
JayStronghawk's Avatar
JayStronghawk
Thumbs up
Originally Posted by FLTRKER
what is a slime compressor?
Ya mean some way to pump up a low tire or do ya mean to put some sealant in the tire to stop the leaking?
I have a co2 kit- but hate to have to load up the tire with gunk.
I am leaving for sturgis wednesday.
THis is the Slime Compressor small enough to fit in your hand and just pumps air although slime does make a gunk thing too if have a bad flat that will get you home ..What shows in the pic will run on anything thats got 12 volt power..
Old 07-28-2009 | 03:00 AM
Devo6684's Avatar
Devo6684
I was looking at one of these at Walmart the other night. IIRC, it was just under $30.
Old 07-28-2009 | 04:01 AM
KSGG's Avatar
KSGG
Slime unit is great. You can use your battery tender lead to power it up.
Old 07-28-2009 | 07:31 AM
grbrown's Avatar
grbrown
On the pressure problem I suggest checking the valve cores are tight. You need to find a pressure gauge which works first time! You may have no other problem than that. If you can't find anything suitable ask your dealer what they use.
Old 07-28-2009 | 07:44 AM
SG 1's Avatar
SG 1
could be the bead leaking. i agree with checking the tires with a soapy solution or windex.
Old 07-28-2009 | 08:08 AM
FLTRKER's Avatar
FLTRKER
Thanks for all the help guys- apparently there is not a universal problem with the rims leaking. Otherwise someone would have posted a story besides mine.
After thinking about how I check the pressure- I expect that I am loosing psi just trying to get a reading. (I hope). I will ck em one last time today and try to get a good reading the 1st time.
I am interested in those 80 degee valve stems.
Old 07-28-2009 | 08:59 AM
FLHTCU Owner's Avatar
FLHTCU Owner
You need a tire gauge with a 90 degree chuck. If you're checking it 5-6 times before getting a good seal, then that is probably the result of the lower air pressure. This is the one I have: http://www.getagauge.com/MotorcycleTireGauges.cfm
Old 07-28-2009 | 10:44 AM
bagman1's Avatar
bagman1
No you cant! The plugs are wired opposite from each other, if you try and plug it in you will be blowing fuses.
bubbacraft
06-08-2023 10:11 AM
skizman
Wheels/Tires
03-12-2017 08:12 AM
kjunguy
06-08-2007 08:48 PM
TattooedAndScarred
05-06-2007 10:32 PM
cutacroshorty
08-13-2006 01:40 PM
Quick Reply: Road King std. looses tire pressure
