Wheel bearing part #? HELP!
I have RC component wheels and not even 10k and the bearings are toast I need to get a set front and rear by Thursday any Ideas? I am leaving 6am Friday for sturgis!
I will get them out of the hubs tomorrow just hoping someone knows the part numbers and sizing so I can try and get going a little faster.
06 FLHX 21 x 18 single rotor front left.
HD part # 9247. all 4 are the same. check the length of the spacer tube they used, as it is extremely abnormal for them to fail so soon. i had that problem and it was the crush tube being too short. it needs to be a few thousandths longer than the distance between the bearing pockets.
a local bearing house should be able to get them much cheaper for you. dimensions are: OD 2.045" ID .998" WIDTH .825"
StreetBrider
Wheels/Tires
29
02-18-2015 01:45 PM
