Air shocks lose a little air--normal and not??
Old 07-26-2009 | 06:47 AM
dh2683's Avatar
dh2683
Originally Posted by thealien
The fittings are a little fussy. When you take the plastic air line out of them sometimes you will see a little deformation at the end. I cut that off (be carefull if you crush the line with pliers the line will not seal properly). When you insert the line in the fitting the plastic push in piece should pop back up (might even have to pull up on it a little). Make sure you push the line all the way in, when you are sure it is in pull on it a little and you will feel when it is properly seated. After doing this to all my fittings I lose very little air!
+1 ON Alien's post. This is where mine were leaking. No problems since on my 05.
Old 07-26-2009 | 09:05 AM
rodeking's Avatar
rodeking
Smile
Good idea, mine loses from 35 down to 20 in about a month. I am getting ready for a 5000 miler and will reset the compression joints and replace the schrader before leaving. My 03 RKC only had to have a few pounds twice a year.
dvldg 66
Air Suspensions
09-27-2013 01:41 PM
PDDGM
04-01-2012 04:05 PM
harleyflo
02-27-2011 08:18 PM
hdsg
09-07-2009 01:09 AM
hardyf111
01-11-2009 01:24 PM
Quick Reply: Air shocks lose a little air--normal and not??
