SE Heavy Breather
SE Heavy Breather
Okay, So I have done a search and read several posts on installing the SE Heavy Breather Kit. I am looking to install this on my 06 StreetGlide and want to confirm the following:
1. What is the correct part number for the kit that will work/fit my 06 StreetGlide?
2. I have the Stage II kit big bore kit installed with the air cleaner. Do I need to purchase a set of "stock" breather bolts as I replaced those with the bolts that came in the Stage II kit? or can I use the bolts that came in the Stage II kit?
Thanks in advance.
Thanks in advance.
