put the wild pig mufflers on yesterday
Many used to say that the 2.0 need updated - but I just spoke with a dealer an he stated newer model 07 and up seem to not need any adjustment.
Can you Wild Pig owners compare them to Bub 7's. Looking at getting the 2.0 and wanted to know how the comparison is as far as deep and loud.
Thanks. Mike
Thanks. Mike
The Stealer say's No as long as you run the stock AC. They seem to come lean from the factory due to the EPA I just put a V&H Fuel pak on just to play it safe. Runs Great! A buddy of mine has a set on and he said it runs ok but thinking about running something to increase fuel. The Fuel Pak is the cheapest way out and easy install. If you plan on doing cam's fuel pak will only handle 26's if you go with bigger cams you'll want something else sert...ect.
