couple questions about gear lube, need help Plz
Old 07-21-2009 | 09:05 AM
Harleypingman's Avatar
Harleypingman
Fluid capacities and specs will be the same for police and civilian models. Don't know about the '07 but my '04 says 20-24 oz in the tranny; 32 oz. in the primary; and, 4 qts (I go with 3.5 to avoid overfill) in the engine. FWIW, if you check Amsoil's website, they recommend 25-50 in all three holes.
The best money you will spend on your bike is the 2007 HD Service Manual for Touring Models and the Police Supplement. The Police Supplement will deal with air ride seat, siren, and other police-model specific issues. On a trip last Friday I stopped for a break at Pat Rogers Speedway HD in Charlotte and they had the 2007 Police Supplement on sale at 40% off list. Give their parts department a call and they can mail it to you:
http://www.speedwayharley-davidson.com/
Old 07-21-2009 | 09:09 AM
07RoadHawg's Avatar
07RoadHawg
'07 models use 32oz in the trans, and 38oz in the primary for a wet fill, 44oz dry.... FWIW
Old 07-21-2009 | 10:56 AM
Gregte's Avatar
Gregte
Default Wet Fill???
Wet fill?? As opposed to dry????
Old 07-21-2009 | 11:27 AM
Unome's Avatar
Unome
Originally Posted by peddler
If you search this forum you'll find alot of info regarding tranny/primary/engine lubrication. Redline Shockproof Heavy or Amsoil Severe Gear 75x-140 will work fine and quiet the 1st and 5th gear whine.
I agree with this.
Old 07-21-2009 | 12:31 PM
07RoadHawg's Avatar
07RoadHawg
Yes.... If you just drain the primary at the plug, it's considered a wet fill. Removing the entire primary cover it's a dry/complete fill. It's all in the manual(s).
Old 07-21-2009 | 12:37 PM
Dandy1's Avatar
Dandy1
I just came back from a dealer in Tulsa, they recommended using 75W140 also. Thanks a bunch for the information.
Old 07-21-2009 | 12:52 PM
garyhendley's Avatar
garyhendley
i run amsoil 20/50 engine and primary and 75/90 sevear gear in the tranny also
use amsoil in all my cars save lots of many and once a year oil changes-ride safe
Old 07-21-2009 | 01:14 PM
peddler's Avatar
peddler
I can understand how this type of tranny lube thread can be confusing. Half or more of the members that post don't tell you what year bike they ride. Does it matter? Of course it matters. There are alot of gear oils (Amsoil 75w90, 75w110 Mobil 1 etc) that will "work" in the Harley 5 and 6 speed trannies however Amsoil 75w140, Redline Shockproof Heavy, and Belray Big Twin Transmission Oil (85w140) will not only work in the 6 speed cruise drive they will also quiet the infamous 1st and 5th gear whine. Hope this helps.
Old 07-21-2009 | 02:38 PM
UltraTheo's Avatar
UltraTheo
I use Amsoil 70-140 severe gear in the tranny and Amsoil 20W50 in the primary and crankcase. Any good synthetic will do in those weights.
vonivo
01-14-2013 09:11 PM
Galdog
Oil Archive (no new posts)
06-26-2011 09:42 PM
fourthhorseman
11-28-2009 10:57 PM
pcooper6149
08-10-2008 06:23 PM
Mad Dawg
01-18-2007 12:28 PM
Quick Reply: couple questions about gear lube, need help Plz
