best way to remove a tank badge.
Old 07-20-2009, 04:38 PM
yank's Avatar
yank
yank is offline
Default best way to remove a tank badge.
I was hoping someone had a good way to remove a tank badge without ruining the paint. I want to remove my 03 badge off of my gas tank. any suggestions?
Old 07-20-2009, 04:40 PM
n8dc's Avatar
n8dc
n8dc is offline
dental floss or fishing line then goo off or some ppg or dupont stuff that removes the tape and residue..
Old 07-20-2009, 04:44 PM
Puttnutt24's Avatar
Puttnutt24
Puttnutt24 is offline
Heat it up first, with either a heat gun or hair dryer
Old 07-20-2009, 04:54 PM
HOGBOY57's Avatar
HOGBOY57
HOGBOY57 is offline
I have done the hair dryer. It works good. And if theirs any glue residue i have used wd40.
Old 07-20-2009, 05:10 PM
cav1429's Avatar
cav1429
cav1429 is offline
that's the way i removed many. First heat it up to loosen the glue then use thin fishing line and work it behind the badge nice and easy the thing will come right off and then WD40 will take off any remaining glue then wax tank.
Old 07-20-2009, 05:11 PM
twofish's Avatar
twofish
twofish is offline
Hair dryer and a closed twist tie to slip under badge, then pull slowly after badge gets hot.
Worked for me on a couple of bikes.
http://www.harleyalley.com/showphoto.../293/ppuser/34
Old 07-20-2009, 06:43 PM
dailydriver's Avatar
dailydriver
dailydriver is offline
Just wait awhile...They're installed at the factory they'll fall off soon enough..
Old 07-20-2009, 08:27 PM
Harleypingman's Avatar
Harleypingman
Harleypingman is offline
The HD tank badges are applied with double-sided tape trimmed to fit the individual badge. A hair dryer and dental floss has worked for me the couple of times I've removed them. The heat gun I have doesn't have a thermostat and will burn paint off metal, so it's never been near my bike.
Old 07-21-2009, 02:21 AM
emwolb's Avatar
emwolb
emwolb is offline
with both of my last harleys that had that cheezy plastic badge on the tank, i've used dental floss. saw through the 3m type of double sided foam tape, that's all holds the emblem on. do it dry, cause if you use wd-40 first it lubes the dental floss sorta defeating the purpose. then after you've gotten the badge off, put them on the shelf so they can collect dust like all the other harley stuff you won't be using, then wipe down the tank side where the badge tape residue is with a soft cloth saturated with wd-40. work it a little and before you know it, you'll have the wax out polishing where the badge used to be. way easier to keep clean without that goofy looking piece of plastic. "BADGES, WE DON'T NEED NO STINKIN' BADGES"
converted
03-14-2013 02:40 AM
Cruzados
10-08-2012 10:01 PM
89Speedy
08-24-2012 05:58 AM
aamodt22
05-29-2011 02:07 PM
leggz
04-09-2010 02:01 AM
Quick Reply: best way to remove a tank badge.
