Brake Fluid
I recently changed the fluid in my rear brakes. For the first time, ever, at 75K miles and 23 years. My pedal was starting to be soft, and I'd have to pump it a few times if the bike sat a while (weeks), so I rebuilt the MC and caliper with new HD parts. This was the first time the system had been cracked. Actually, I did open the rear fluid resivoir about 20 years ago to note that everything was fine, buttoned it up and left it alone. That DoT 5 brake fluid is some magic stuff there. Everything looked excellent inside. No corrosion at all. Some slight wear. I think that air was actually leaking in at the rear brake line to caliper connection. I'm going to slowly change all my hydraulics over to DoT 5 whenever I rebuild a system. You guys stuck with DoT 4, too bad.
