Floorboard extension install question.
Old 07-20-2009 | 01:13 PM
MOPAR MAN's Avatar
MOPAR MAN
Default Floorboard extension install question.
Bought some floorboard extensions and went to install them but can't get the rear bolt on the right side to budge. I'm afriad to put too much more pressure on it for fear of breaking it. Anyone else have this problem or suggestions on removing it? As always thanks for any help.
Old 07-20-2009 | 01:19 PM
soos's Avatar
soos
I have come across the same situation. I have used a short pipe for added leverage. You are trying to break a 1/2-13 bolt free. As long as you have the allen wrench properly seated you should be able to loosen the bolt.I am assuming that you are working on an "08 or earlier model.
Old 07-20-2009 | 01:28 PM
MOPAR MAN's Avatar
MOPAR MAN
Thank's I'll try that. It's on a 07 Ultra. Do they put locktite on the threads from the factory or do you recomend using it on reinstall?
Old 07-20-2009 | 01:59 PM
joewg3's Avatar
joewg3
That's what I had to do. That was the only pain during the install.
Old 07-20-2009 | 03:10 PM
HDRider2002's Avatar
HDRider2002
i eventually had to put the allen wrench on it and given there wasn't much clearance give it a few "taps" with a rubber mallet just enough to get it moving, did the trick for me. If you manage to break that bolt by hand, i'd be pretty impressed.
Old 07-20-2009 | 03:14 PM
Wassup8687's Avatar
Wassup8687
Some can be really on there.
I'd recommend using Loctite when you install the new bolts so they don't vibrate out at an inopportune time.
Old 07-20-2009 | 03:38 PM
jsimo7's Avatar
jsimo7
get a set of allen wrenchs that have a 3/8 ratchet base and it will be a bit easier .... and yes to the locktite on everything
Old 07-20-2009 | 03:42 PM
jdreed520's Avatar
jdreed520
I just did mine yesterday....and i used a Allen wrench that was a socket for my 3/8 breaker bar and one it broke loose i used a regular allen to get it out.
racin45
02-28-2014 10:57 PM
HDGent
11-11-2010 08:47 PM
Rabid
08-10-2009 07:34 PM
HD Renegade
05-21-2009 12:37 AM
urdollar
05-27-2008 02:42 PM
Quick Reply: Floorboard extension install question.
