Heat-related muffler gasket replacement?
I have noticed that my bike gurgles on deceleration until it warms up. My suspicion is an exhaust leak that seals once the metal has expanded. I tightened my ring clamps but the problem persists. In light of the leak being heat-related and only for a short period in each ride, would it be worth replacing the gaskets or just leave it alone?
Crap. My suspicions were wrong.
I just had a closer look at the rear head pipe. There is a thin crack. It was not there when I did my pre-weekend ride inspection but the gurgling was present before. I traced the crack with my finger and it disappears out of sight, which suggests to me that the original crack was always there but I could not see it.
I seem to recall an aftermarket mod that changes the stock head pipes into a true 2-into-2 setup. Does anyone have the website? If I am going to need to fix my rear head pipe, I may as well consider the option of the conversion.
Would leaving the crack remain until the end of the riding season be hard on my motor? It is only 1/32" of an inch thick and feels to be about 1/2"-1" long.
It sounds like you have stock headpipes. Check with some Indies or your dealer for some take offs. They probrably have a bunch of them laying in a scrap pile. Dirt cheap or free. Talk to a mechanic having a smoke out by the service doors..
