Removing old grips ?
07-19-2009, 08:12 PM
Getting ready to do my bar swap and I'd like to be able to salvage the Iso Grips I have on there now. Whats the best way to get that left grip off without tearing it up?
07-19-2009, 08:14 PM
I just grab ahold of it super tight and twist it. That will break the bond with the glue and it will pull right off.
Steve
07-19-2009, 08:16 PM
what did you use to put it on originally?
I'd try twisting hard first..
Acetone (finger nail polish remover) will loosen super glue...but be careful around your paint!!
07-19-2009, 08:36 PM
Tilt the bar so it's grip down and squeeze Goo-Gone into the crevices. Goo-gone will eat through the glue without harming the grip. Once it's soaked twist the grip and it should pop right off. Goo-gone won't harm your paint like some other glue removers.
Good luck
07-19-2009, 09:49 PM
Try electronic contact cleaner spray. See if you can get some under the grip and move it a bit.
07-19-2009, 10:18 PM
I use a hacksaw blade and work it between the grip and handle bar.
larry harding
08-01-2014 08:13 AM
sven556
04-17-2014 12:06 AM
SteelWill
06-18-2013 05:58 PM
1forrest1
02-08-2013 07:26 AM
Kansasjase
10-30-2009 07:05 AM
