SE AC Back Plate and 50mm carb
Old 07-19-2009 | 06:33 PM
loc's Avatar
loc
Default SE AC Back Plate and 50mm carb
I was cleaning my air filter on my 08 Ultra and noticed the the throttle body and the SE back plate dont line up very good. the bottom the throttle body is "inside" of the AC opening by about 1/8inch or so and the top just the opposite. I was wondering if others had this same "offset" issue?
Old 07-19-2009 | 08:11 PM
dawg's Avatar
dawg
Is the black bracket from the stock AC removed? This was a problem with the original 08 SE kit as the instructions were misprinted and folks left the bracket on which caused a gap. Make sure your bracket up top is removed. Here is a pic showing the bracket that needs to come off.
Old 07-19-2009 | 08:33 PM
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
As noted above, it sounds like the OEM throttle body support bracket was not removed when the AC was installed.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Old 07-20-2009 | 08:28 AM
loc's Avatar
loc
Nope, I took off the bracket when I installed it. There is no gap just seems the plate's circle opening does not match perfectly the throttle body opening circle. I will try to get a picture of it.
Old 07-20-2009 | 01:42 PM
dawg's Avatar
dawg
Elongated mounting holes maybe?
WestTexasRanger
11-16-2016 03:51 PM
Dyno Don
Exhaust System Topics
11-08-2013 09:17 AM
CrazyBoom
12-28-2011 03:27 PM
Garemlin
09-16-2010 06:22 AM
Garemlin
03-04-2008 07:54 PM
Quick Reply: SE AC Back Plate and 50mm carb
