- need inexpensive lights..
I have a 2004 electra glide classic. I'm looking for INEXPENSIVE lights that will increase visibility to the rear. I've been considering adding a small red light at the bottom of the saddlebag just below the rail, a larger one in between the two rains and one larger strip or something on the trunk. I want MUCH more flexibility. The lights I've found haven't been what I'm looking for. Some are..but the cost is prohibitive. I don't have hundreds of dollars to spend. If anyone knows of any such lights I can look at..please let me know. Thanks
Inexpensive = cheap in more than one way. Low quality. Low output. Short life. Don't sacrifice when it comes to your safety. Get yourself some Radiantz turn signal clusters, a Biketronics Tailbones run/turn/brake module and a BriteAssLight tail light. That'll light up your ***. If nothing else at least go for the clusters and the module. Cost under $100.
Best bang for the buck IMO is the conversion kit that utilizes your existing lamps for running and brake lights. I had it on my 01' FLHT and the new Ultra will get one soon!!
Auxiliary Running Light / Brake Light / Turn Signal Conversion Kit
Turn signal module adds an auxiliary brake light and running light function to your existing turn signals for auxiliary rear lighting. Red lenses glow when the headlamp is on, and increase in intensity when brakes or turn signals are activated. Easy-to-install, the kit simply plugs into your existing wiring harness. Red turn signal lenses are included. Meets DOT requirements.
This product is available in multiple variations. Be sure to look for the one that fits the specific model and year of your motorcycle.
69462-06A
$57.95
69462-06A
$57.95
69462-06A
$57.95
69462-06A
$57.95
Check this tread https://www.hdforums.com/forum/touri...light-bar.html
I am looking for a couple of stips just like the one I used to make some light bars for the area between my saddlebag rails. I to am not a rich man and can't see paying 300-500.00 for lights that I know I can duplicate or at least custom build a hell of a lot cheaper and it will be one off..
Joe
Joe
oneshotdog
05-25-2017 11:34 AM
K2
10-30-2008 03:42 PM
