Notices
Oil Temps on Various Builds
Old 07-15-2009, 07:48 AM
jcbpa's Avatar
jcbpa
jcbpa is offline
Cool Oil Temps on Various Builds
Okay, here we go... for those who monitor oil temp, what are you running temp wise on a warm day after 1 hour on the highway?
95
103
107
110
117 and up?
Same question but what does your temp run when you are in traffic on a warm day?
What oil are you using and have you noticed a drop in temp if you went to full Synthetic?
Old 07-15-2009, 07:58 AM
lkr0's Avatar
lkr0
lkr0 is offline
you forgot 107
Old 07-15-2009, 10:08 AM
jcbpa's Avatar
jcbpa
jcbpa is offline
Yup... thanks, just added it.
Old 07-15-2009, 10:14 AM
FastHoss's Avatar
FastHoss
FastHoss is offline
88tc, 100degrees ,80 mph over hills and what not oil temp 230 run full syn V Twin Mobile,oil cooler,flater ground 215 degrees
Old 07-15-2009, 05:22 PM
iclick's Avatar
iclick
iclick is offline
Is an 88 or 96 not a "build" just 'cause it's the stock displacement? This is crass discrimination.
Old 07-15-2009, 05:44 PM
Arizona's Avatar
Arizona
Arizona is offline
The 95" Stage II motor in the '05 EGC I had previously ran about 212* average on the freeway on a hot day. It had the H-D Premium oil cooler.
Old 07-15-2009, 08:32 PM
cropsure's Avatar
cropsure
cropsure is offline
103 stage II. HD premium oil cooler. Been 100 + for the last couple of weeks. Temp running anywhere from 235 to 265. Redline oil. Temp actually goes down when stuck at a light. Haven't figured that one out.
Old 07-15-2009, 08:38 PM
EasternSP's Avatar
EasternSP
EasternSP is offline
Received 24,691 Likes on 9,284 Posts
103 stage V with H-D oil cooler and Baker DD6 tranny.
highway - a little over 180 at about 90 degrees.
in slow traffic - around 230
Old 07-15-2009, 09:44 PM
tom73's Avatar
tom73
tom73 is offline
Maybe your map is too lean in the 2500 - 3000 range. Could have too much timing. What kinda fuel mileage?
My HQ 103 has temps (Measured at the pan) on hot day when moving 230 -240. If I get stuck in traffic or slow pace it will creep up to 250. Anything higher than that and I take a break. Went back to dino oil from synthetic and no change in temps. Got tired of paying $10 per qt. Figure I can change the Castrol dino oil every 1500 for $2 per qt.
Old 07-15-2009, 10:17 PM
cropsure's Avatar
cropsure
cropsure is offline
Yeah, it's back in the shop as we speak. This will be the 4th time on the dyno. It's pinging now just when I'm running 70 mph with the cruise set. I would say that's a little lean! Fuel mileage is around 44 to 45 mpg on the hwy. I installed Dakota Digital guages a couple of weeks ago and they give head temps. That temp. has been running right at 290 - 295. Dealer says that's totally within reason. Hope he is right.
Quick Reply: Oil Temps on Various Builds
