Shifter arm vib'ed off shaft @ lunch !!
Old 07-14-2009 | 05:57 PM
bobbydeuce's Avatar
bobbydeuce
My heel shifter came off too, luckily I heard it hit the ground..did a u-turn..and there it was lying in the middle of the road ..I decided to leave it off.
Old 07-14-2009 | 06:26 PM
teamstersteward's Avatar
teamstersteward
owning a Harley is like a box of chocolate
Old 07-14-2009 | 06:34 PM
SA315B's Avatar
SA315B
Before you crank down hard with a wrench consider using lock tight.
Old 07-15-2009 | 07:23 AM
SOLOLUCKY's Avatar
SOLOLUCKY
Default heres the fix
here is the fix i used. so now along with zip-ties,epoxy putty, and other misc stuff...rubber bands are now in there.
It got me home...thats all that mattered.
Attached Thumbnails Shifter arm vib'ed off shaft @ lunch !!-harleyshifterfix-1.jpg
Old 07-15-2009 | 07:30 AM
Jerry/MD's Avatar
Jerry/MD
Default Another Victim................
Yep, started a thread on Monday about the same issue. Lost my heel shifter while riding on Sunday. Never found it. Had to resort to toe shifting again. Tuesday....I installed the H-D billet shifters and made sure to use Loctitie. From now on, the screws will be checked at regular intervals.
Old 07-15-2009 | 09:39 AM
Geezr Glidr's Avatar
Geezr Glidr
My heel shifter fell off also --- 09 EG Classic. Turned out that the dealer just didn't push it on all the way & tighten it up. (When the mechanic rode it out to me the day I picked it up, he asked if I wanted them lower & closer to floorboards. I said, sure, as long as I'm right here.) I turned around, and went back & found it. Tighten things up! I know a guy that swears that a little motor oil on the threads is better than LocTite.
Old 07-15-2009 | 11:50 AM
SOLOLUCKY's Avatar
SOLOLUCKY
I was taught in high school to put a dab of oil on lug nuts. I guess it lets the threads skip easier for tightening. But would it not allow for threads to allow easier loosening?
Old 07-15-2009 | 12:05 PM
nskitts's Avatar
nskitts
I kept hearing a ping at speed and thought, "Oh no, here we go with the engine ping thing." But after further investigation it was my shifter which was loose.
Sometimes parts fall off Harleys, they do vibrate a bit.
Old 07-15-2009 | 01:04 PM
2whlr4life's Avatar
2whlr4life
Arrow be done with it
It happened to me too, never found the shifter. Bought one cheap off 'Craigslist', loctite it and put a nut with a nylon lock on the the threads that hang out the bottom. Not noticeable and end of the story!
PFR-Captain
06-05-2014 02:27 PM
DarkMatter
07-11-2012 10:34 AM
albngore
01-10-2012 08:44 PM
evil_monster
03-04-2009 08:53 PM
JacktheBagger
10-02-2008 09:21 PM
Quick Reply: Shifter arm vib'ed off shaft @ lunch !!
