Cruise Control Stopped Working, Need Advice
03 ultra - 22k miles. i did service this past winter at the dealer. one of the things the dealer was going to do was take up the 1" slack in my throttle cable. they didnt at that time and sited i needed to order a lower control housing to do it right.
i got the part and brought the bike in for a drive in for them to put on the lower housing and tighten up the slack. 3 hours later at the dealer and the lead mechanic came out and asked me if the cruise control ever worked. i said yes - which it did. he double checked all the electrical connections, but just could not get the cruise to work. the other functions on the controls work fine.
i could not stay and have them continue to trouble shoot the problem and i would rather not bring it back in if you can help me figure this out. its too much of a hassle.
my first thought is to try to do the procedure to reset it in the back of the SM, but am hoping that some of you may have a few other things to look at. have a long trip planned in a couple of weeks and was really looking forward to using the cruise.
thank you - tin
thank you - tin
they never replaced the throttle cable, just the housing and took up slack. will definitly check fuses. the light does work on the switch itself. thank you!
pull the A/C and make sure the cruise cable is connected to the throttle body. It looks like a throtle cable. If that doesnt work there is a diagnostic procedure in the manual. It will test each item that effects the cruise. Sorry but I cant remember right now how to do that. Good luck
tin
Ok, this might sound dumb but.. You said that all the controls worked BUT didn't say if they checked the brake light. Just speaking from experience (screw up on my part) the small button on the switch for the brake light which of course disengages the cruise breaks very easy. When I put new bars on I didn't keep the hand brake open when the housing was put back together. The brake light stayed on and of course the cruise didn't work. Something easy to check and/or eliminate as you diagnose.
thank you
