headlight bulb alternatives???
07-22-2009 | 01:34 AM
thanks for the input guys. i went to advance auto parts and got a pair of hella 9003 style h4 bubls. now i got a spare sitting on the shelf for when the first one goes out. i found that the hella, like the osram are top quality. odd, but it's got the slight blue tint, for the higher frequency light. sure are better than the stock bulbs. actually this bulb, looks identical to the 29.95 hi performance headlight bulb as the one harley sells. thanks again for the replies.
07-22-2009 | 11:25 AM
how about the wagner BP1210/H4 bulb?
Quote:
Originally Posted by
wolfshead1
Get the Osram off road,think it is 90 or 100 watt.Bout $12 if you find them.Twice the light.
will the wagner
BP1210/H4 work in a 09 ultra?
ran this bulb in a Nomad with no problems..it is a 80/100
07-22-2009 | 09:19 PM
PIAA bulb
IAMSWUTIAMS
I've been running PIAA's for 3 years now, no problems, nice light.
What model PIAA bulb are you running?
07-22-2009 | 09:44 PM
I have had good luck with Sylvania Silverstar. Much whiter light without increased heat in the socket. Make sure you stick with a 55/60watt lamp.
07-22-2009 | 09:46 PM
12-05-2009 | 05:41 PM
Hey Cujo,
what bulbs are you running in the spots?
Thanks
12-05-2009 | 10:52 PM
Don't try to run high wattage bulbs without adding relays. You'll fry the switches eventually. Ask me how I know.
12-06-2009 | 09:18 AM
I see the PIAA's have anti vibration H4 bulbs. Is that what should be ran? I would think that may extend the life of the bulb.
12-06-2009 | 09:23 AM
vtwin1340
Is that a typical lifespan for the H-D hi performance bulb?
For me yes, I went through two of them before going back to the OEM blub.
Houston_t
03-17-2014 04:33 AM
Thumper26
09-12-2013 09:26 AM
trappermarc
04-16-2012 11:31 AM
bluedemon06
04-13-2009 05:06 PM
HaggisMan14
08-31-2006 06:48 PM
7065 ,
bp1210h4 ,
bulb ,
bulbs ,
davidson ,
flhtcu ,
h4 ,
harley ,
headlamp ,
headlight ,
light ,
osram ,
performance ,
red ,
reviews ,
wagner
