Antenna Cable Extension?
http://cgi.ebay.com/ebaymotors/ws/eB...lenotsupported
i put a tour pac on my 08 road glide a month ago, the extra cable you are looking for is under the left side cover and is plastic tied in place to the right of fuse block cut the plastic tie and pull the cable from under the seat you will have more then enough cable the light wires and antenna cable are in the same plastic wire cover
yes, the antenna wire is in the plastic casing that also holds the wire for tour pac lights,cut the plastic ties along top of frame holding antenna wire in place and work your way foward, it will go into a plastic casing that both antenna cable and tour pac wires run through,the wire goes down into the left side cover and is in a loop on right side held in place by a plastic tie,cut the plastic tie holding it in place and gently pull up through hole, there is at least 10" of wire run along frame, secure in place and into tour pac
7622900, 7655609, am, antenna, davidson, discontinued, extend, extender, harley, installation, instructions, pdf, relocation, splice, wire
