GPS Hardwire ?
Be careful here. Some cig plugs have a regulator in them to drop the voltage to something lower. Not a fuse, a regulator. If you cut it off you need some other form of regulation. The zumo expects 12v, so you are ok there, not sure about the nuvi.
I wired my Zumo buy running the cable down the handlebar inside the fairing and the over to the back of the cig lighter. I have a 2A fuse inline to protect the Zumo.
"Cut the plug off" ... if you mean, cut the whole cigarette lighter assemble off, I'd be hesitant to do that. I have the nuvi 500 hard wired into my 09 Fatboy. What I found was this ... there's a circuit board inside the cig assembly with lots of electronic parts on it. I'm not an electrical engineer, but my guess is they didn't put all that stuff in there to baffel me. Initially, I was gonna take the circuit board and put some heat shrink around it but I couldn't find any heat shrink big enough. So, I just used the existing housing and cut the front part off and soldered some wires to the hot and return point on the circuit board. The wires were sticking out of the front of the assemble and I put some RTV in the front of it to keep the water out. I put a bead around the outside of the housing too prior to snapping it back together just for safety sake. So, there's still the "fuse" issue. The part of the housing that I cut off was where the fuse typically goes. So, dunno about the long term effectiveness of this, but I just hardwired the fuse into the hot lead with solder and heat shrank it. Guess if the fuse blows, its not gonna be a quick fix, but, I't won't be a big issue to cut it out and put another in. I had a spare hot 12 V nipple behind my front light hidden behind the lighting assembly and I just hardwired it into it. I used some of the stick on velcro stuff and hid it the cigerette assembly in there. You don't even know its there. So, the good and bad news is, every time I turn my bike on the GPS plug is hot irreguardless of the GPS being plugged in or not. Maybe I'll get really ambitious and wire an on/off switch ... nah ... if it blows, I'll just get another one . Its been going strong for 4 months now and I'm very happy with the short term result ... ask me 3 years from now and I'll let you know about the long term .
Don't know your device, but almost certainly a "no-no".
MOST satnavs will have electronics in there to reduce the supply to 5V - why? Because they invariably need to be paired up with a PC at some stage in their life and the USB is 5V and very smooth.
I would never cut a cig lighter connection off
