Neutral Light Problem
07-09-2009, 10:56 AM
2000 Road Glide Neutral Light flashes and stays on at road speed at any gear - does anyone know why or can you help. Thanks.
07-09-2009, 12:14 PM
Check the connections on your neutral indicator switch. Or the switch itself might be bad.
07-09-2009, 12:20 PM
Yup, neutral indicator switch is probably shot.
07-09-2009, 01:13 PM
If they change the shift pawl and the switch and the o-ring and it still happens, Can there be a problem with the machining of the trans case?
07-28-2009, 08:03 AM
Moisture in the oil will also cause this. Found that out the hard way.
07-28-2009, 08:34 AM
Had the same problem on my bike. Ended up being the neutral switch. The stealer I bought the bike from couldn't fix it after 3 tries and told me I may need to have the whole transmission ripped apart. Went to another dealer and he had it fixed in 5 minutes by replacing the switch.
Dazzauk
EVO
05-09-2016 02:36 PM
hdnvn
02-25-2012 07:29 AM
RAUL1728
04-17-2010 01:47 AM
skydrifter
01-22-2010 03:42 PM
mradl2
08-06-2006 02:19 AM
07 ,
2000 ,
2007 ,
3390059c ,
classic ,
davidson ,
electra ,
glide ,
harley ,
light ,
neutral ,
problem ,
road ,
switch ,
ultra
