autotune?
autotune?
Can I hear about yall's experiences with these new autotune systems. I know there are a few out there like DTT, Tmax, and PCV. Im trying to decide whether or not to make the switch and I want to hear what yall think. I currently run the PCIII and it has been good but there have been slight issues since the day I started using it which im thinking are related to the PC. Thanks guys
Call Jamie at Fuel Moto and ask his opinion. He sells most or all of these tuners, for sure the PCV and T'Max.
I installed the PCV-AT on my '07 SG and am very satisfied. This topic has been covered extensively here and if you search on "auto-tune", "PCV", or "Fuel Moto" you'll get plenty of feedback--less so for the other tuners. If you have any specific questions ask away.
I ran the DTT for some time and it was a good tuner, but had some quirks. Any Alpha N tuner (DTT, Tmax) are somewhat limited but overal do a really good job if the base map is close and you dont mind fussing with them a bit. I have since switched to a TTS Mastertune and love it. Unlimited capabilities, and is not overly hard to learn to use.
Any tuner, you need to read a lot, understand how it works and be willing to make some adjustments to get it right.
Be advised that TTS is not an auto-tune system. It was developed by Steve Cole, the creator of the original SERT for HD, and works with the stock ECU and narrow-band O2 sensors, offering many features, some of them unique. But like the stock system closed-loop mode stops at about 50% TP, and to tune accurately for WOT you'll need a dyno tune. Also, closed-loop can be altered only down to about 14.2:1. The PCV-AT auto-tunes throughout the RPM and TP range, including WOT.
These two tuners are like apples and oranges, but in the right hands either will provide an excellent tune. A PCV-AT from Fuel Moto, given one of their excellent base maps, is a true auto-tune system for AFR that you can literally install and ride. Detractors will say that ignition advance is not auto-tunable, which is true, but the key is to have accurate values placed in the base map at the outset.
Using autotune on PCV can you insert a canned fuel map, the AFR map, and find the canned map completely modified by the autotune module?
If so, can you also download the such modified fuel map to give to another rider with the same bike, AC/Pipes and PCV but no autotune, to upload into it's PCV?
So if I use autotune and get modified the map, can I reove the autotune and use only that map previusly created by the autotune?
Or am I obliged to have the autotune permanently installed if I want to use an AFR map that correct my bike's fuel mixture to it's optimum?
I searched around but didn't find final response...
Jeffinburlington
37
12-29-2014 11:02 PM
