How do I remove the Steering lock? 09 FLHX
Old 07-07-2009, 07:10 AM
ken b's Avatar
ken b
ken b is offline
Default How do I remove the Steering lock? 09 FLHX
I am doing the Garage Door opener mod and I need to get the Steering lock off to pull the rest of the switch console out.
Looking below it I see a metal tab. That tab I have pushed in but I am getting no where. The lock doesn't budge.
I just need a clue on getting this puppy off.
Old 07-07-2009, 07:15 AM
skydoc's Avatar
skydoc
skydoc is offline
Turn left and pull up while pushing tab. Have fun gettin' it back on!
avcaruso's Avatar
avcaruso
avcaruso is offline
Received 1,315 Likes on 176 Posts
I think you have to turn the key counterclockwise to get the tab to depress. My manual is home and I am at work and have done it a few times but not sure which way. Try turning the key to the left and then depress. I'm sure you'll have an answer shortly.
Old 07-07-2009, 10:45 AM
heng's Avatar
heng
heng is offline
Delete info
Old 07-07-2009, 01:15 PM
Cowracer's Avatar
Cowracer
Cowracer is offline
Theres no screws involved
Depress button underneath with screwdriver blade while turning KEY ccw. (the button release the stop for the key, the key releases the latch for the ****) The **** and shaft will unlock and can be pulled out. This can be done in any ingnition postition.
Replacing it is easy, you just have to remember to have the KEY turned to the left (CCW) when inserting it.
After the ****/shaft is off (gee, that sounds dirty) you can remove the nut and spacer, then remove the fairing cap.
Tim
Old 07-07-2009, 02:54 PM
iclick's Avatar
iclick
iclick is offline
If you have small hands like I have use one finger to push the pin up instead of a screwdriver. My ring finger fits perfectly, and it's much easier than using a screwdriver.
Old 07-07-2009, 02:57 PM
flyingace's Avatar
flyingace
flyingace is offline
You get the service manual, and learn how to do it RIGHT.
I've seen a LOT of wrong explanations on the internet.
Screw this up, and your gonna have a bad day. Trust me.
springer 03's Avatar
springer 03
springer 03 is offline
What is the garage door opener mod?
Old 07-07-2009, 02:58 PM
dawg's Avatar
dawg
dawg is offline
Received 3,246 Likes on 1,852 Posts
attached
Old 07-07-2009, 10:14 PM
ken b's Avatar
ken b
ken b is offline
Awesome, Thanks!
Quick Reply: How do I remove the Steering lock? 09 FLHX
