My front brake is always squealing a tad when not engaged. When I pull the front brake lever a bit, the squealing goes away. Can someone please explain why this would happen, and if there's anything I can do to remedy it?
its called brake drag, and is somewhat normal. best advice is to pull the calipers and clean the pistons and pad pins with brake cleaner. lyndall has a tutorial on their site.
