Just e-mailed Jamie at Fuelmoto...
I've had my Rinehart pipes for awhile now, as well as the SE Heavy Breather, and think I'm going to use Jamie's Power Commander for my fuel management system. I already have the SERT, but think I'm going to go Power Commander instead, but I've got some questions. For those of you that have the PC, do you reccomend the III, or the V, and why? Also, I'm planning on doing 103 stage 2 this winter, and if I use the PC III, or V, do you reccomend the auto-tune feature? If so, why? And last but not least, if using the auto-tune, do you believe it gets you close enough to "optimal tuning" without dyno'ing. I don't mind giving up 2-5 HP/TQ, but wouldn't want to lose much more than that. Thanks fellas, I appreciate your input!
V because it's smaller, thinner and easier to install plus it's compatible with the autotune. If you are going to build a standard 103 then the autotune is probably not necessary as Jamie has a large database of maps.
If you are going to go extreme then the autotune is probably a great idea.
Detractors will say that ignition advance isn't altered by auto-tune, which is true, but that is not as important for performance as the AFR tables, and is generally optimized in Fuel Moto's base maps.
I'm not sure how you deal with a PCV on top of SERT, but I'm sure it can be done and Jamie would be the one to ask. If you order the PCV be sure to tell them ahead of time. Since SERT is adjustable I would think you would have to get the ECU back to stock or Stage 1 for one of Jamie's PCV maps to work properly, but I'm just speculating since I've never done it.
Kevinmach1
04-16-2012 01:27 PM
