Rear Shock Air Pressure
Old 07-05-2022 | 02:41 PM
KaptKane's Avatar
KaptKane
2nd Gear
Default My problem
My 2010 Ultra Classic has Air Suspension with a onboard compressor. I would keep the pressure at 120lbs PSI (this bike has a “training wheel” setup so I have the keep the drive wheel firmly on the ground). The system would hold the pressure for several weeks. Last time we took it out the pressure was at about 60lbs PSI I pumped it up and it immediately started to bleed off. Now, over about 2 minutes it will bleed back to 60lbs and hold there. I’ve checked all the connections with soapy water and nothing shows up. Any ideas?
Thanks in advance
Sreynold1
07-05-2022 05:42 PM
Hurleybird
03-08-2010 03:05 PM
leadman
03-25-2009 02:27 PM
caorig
09-18-2008 04:04 PM
TowJam
03-10-2007 12:10 AM
Quick Reply: Rear Shock Air Pressure
