Rear Shock Air Pressure
07-05-2009 | 04:32 PM
Quote:
Originally Posted by
davewear
45psi works for me, stiff with good ground clearance when solo and comfy when two up. i'm 220, she's 125.
Wish my lady was still 125.
07-05-2009 | 10:42 PM
125
cromagnon
k that was funny, you win a prize! here she is....
07-06-2009 | 12:00 AM
Sorry, I was going to respond to this thread but was momentarily distracted. What were we talking about before davewear threw us all for a loop?
07-06-2009 | 03:16 AM
I run... umm. twenty... errr.. fiveeeee in my... 09SG. Dam that prize is... distracting.
07-06-2009 | 05:29 AM
Running 25 solo in my 08 ultra. I am 6'3 242 lbs.
07-06-2009 | 05:40 AM
davewear
Where do I pick it up?
08-01-2012 | 08:10 AM
davewear
Davewear's sig picture tells she must weight more... Okay, picture of her tells other ;-)
08-01-2012 | 08:31 AM
2012 FLHTK 30-35 lbs @ 210 lbs & "I am too afraid to ask" (she used to be 125lbs too, you lucky SOB)
08-01-2012 | 08:35 AM
If I set my compressor limitor at 20lbs, would it be safe to use for adding air without harming the seals.
Best
08-01-2012 | 08:51 AM
lets slow down a bit on this on. you guys with older tourers will blow out your lines if you use the numbers some of these guys are listing on thier newer bikes. My 03 classis is between 12-15 lbs. for two up and gear. check your manuel befor you turn on the compresser.
