Rear Shock Air Pressure
Old 07-05-2009 | 10:21 AM
dstegjas's Avatar
dstegjas
In my 04 RK custom I run about 10 pounds when I ride by myself. I am at 230 pounds and that gives me a nice comfortable ride. If the wife is with me I usually run about 18 to 20 pounds. Anything more then that and a bump in the road will give me a pretty good jolt.
Jim
Old 07-05-2009 | 10:35 AM
TNTHarley's Avatar
TNTHarley
I run 20 when riding 2 up on my '08. Can't imagine running more than that.
Old 07-05-2009 | 12:11 PM
ropin4gold's Avatar
ropin4gold
09 EGS I run 35psi. Total load of me, my gear, and tools is about 260lbs.
Old 07-05-2009 | 12:27 PM
EricD10563's Avatar
EricD10563
I run 30 or so solo and 40 with the wife. I have not noticed any loss of pressure.
Old 07-05-2009 | 02:39 PM
emwolb's Avatar
emwolb
with my streetglide, i used what was recommended in the owners manual. between 5 and 10 psi. hit some potholes, and found out from other sg owners that 20 psi for my 200# of bodyweight would be right. this was great. i run it at 20 now. the streetglides have a shorter shock and need more air than the longer roadglide and electraglides. no longer does the suspension bottom out. i hope this helps. check with other riders who are riding a similar bike as yours is the best suggestion i can give.
Old 07-05-2009 | 02:48 PM
meintel's Avatar
meintel
I run 40 psi in my RG shocks
Old 07-05-2009 | 02:52 PM
max56's Avatar
max56
I run about 15 for solo in my 07 RK Custom.
Old 07-05-2009 | 03:07 PM
frydaddy96's Avatar
frydaddy96
Changed the oil in them yesterday and have them at 14 psi riding 2-up. A couple of roads that we ride have some dips that would normally bottom the shocks out with 20 psi. Today no bottoming, no jolt, just cruised right on thru. '08 RG
Old 07-05-2009 | 03:16 PM
cromagnon's Avatar
cromagnon
I keep the pressure at about 7 lbs if I'm the only one riding. Two up, I take it to 17 lbs.
The bikes an 05 and never had a leak. Looks like you got a defect.
Old 07-05-2009 | 03:32 PM
davewear's Avatar
davewear
45psi works for me, stiff with good ground clearance when solo and comfy when two up. i'm 220, she's 125.
Quick Reply: Rear Shock Air Pressure
