any pics of tour pac pushed forward?
How does the TP backrest work with the seat backrest? I tried the TP backrest alone before pulling the TP back and found it unacceptable, being too high and forward with no lumbar support. That's when I proceeded with using the Mustang backrest and moving the TP back. Now that the TP is moved back I wonder if there would be any improvement by adding the TP backrest. OTOH it would have to be positioned perfectly, as too far forward wouldn't work and too far back I wouldn't touch it--and the TP in its present configuration can't be moved, I don't think.
Other HDF'ers have done this with their Ultras. Whether you can consider the effort a "major pain" is personal to you. I seldom ride with the tour pak on the bike and I don't currently use the HK headunit/CB parts, but will, probably this fall or winter. For me, the effort to have the CB available with and without the TP on the bike will be worthwhile. The radio antenna is not relevant to me because I get satisfactory results with an antenna inside the fairing.
I haven't done it, and HPM gave a good summary, but I have a few comments. After removing the old hardware you'd need to install the front docking kit (53803-06) and the rack (53260-02). I assume the part numbers for your '08 are the same as for my '07. Be forewarned: Installing the docking kit on my '07 was a Royal PITA (caps intended). It took me more time than I feel comfortable admitting, but suffice it to say that it was a real can of worms, bad enough to make even a veteran DIY'er let the dealer tackle the job, but get a quote first. Fabricating and jury-rigging the solo rack to sit further back was a cakewalk by comparison.
Thanks for the advice all. It's something I've always considered doing since my wife rides with me only once in a great while, but I don't want to take the tour-pak off entirely.
I'd probably want to leave the two antennas mounted to the tour-pak right where they are, so that would lessen that hassel. But, the work aside, I'm wondering if it would look strange with the rear speakers sticking too far forward...
I wish there was a pic out there of this done to an ultra (with the speakers still on the pak). I've searched for a long time and never found one. Every time this topic comes up, it grabs my interest again.
