Oil scavenger
Seem like overkill IMHO. For my first oil change, I just heated it up to temp then up on the lift with a custom shim on the rear lift board. This "tweaked" the bike into a slight downhill position and got most all of the oil out.
After that it's all Amsoil for me so I really don't care that much if a little of the good stuff remains after only 2 or 3K miles.
Tilting the bike shouldn't help all that much since the oil is in the engine part of the system (downstream from the drain), but someone here once mentioned a trick where running the engine (after the oil was drained) for about three seconds pumped another half quart from the engine to the sump to be drained. I have not tried that trick, but I am thinking about it when I switch to synthetic oil.
Beary
Beary
jcrawford14
Oil Archive (no new posts)
10-25-2007 10:47 AM
