taillight module, great for safety, cheap too.
i have installed this taillight module on my last three harleys. it's a great safety feature. imagine this, you're riding a harley that has one taillight, the element burns out, or fails. you're riding down the hiway just looking to get ran over by having no taillight. with this module that costs around fifty bucks at harley shops, you have three taillights. there is a module that plugs into the taillight/turn signal wiring under the seat. it's a five minute job, even if you're lazy and slow like me. no splicing. it comes with the correct red turn signal lenses that will fit your model. it makes your turn signals glow red for running lights along with your taillight. they're plenty bright, and it gives you three lights on the rear, the best improvement for safety i've found, please consider it, as it may save your life.
the module kit which includes red lenses for your model, is listed in the 09 parts and accessories harley catalog, on page 657. i hope this helps someone. i let a buddy ride my streetglide last nite, and it does look bright from the rear. far safer in my opinion. and it an easy install. so easy even a caveman could do it.
i prefer the older module that does not incorporate the running light function myself. the running lights are bright! so much so that it looks like you are running with the brakes on. if you modify the module, you can eliminate the running lights function and just have the turn signals illuminate as brake lights.
Tailights that are LED and VERY BRIGHT
I am working on a simple solution that gives me the brake lights that are very bright even when the AZ sun is in the eyes of the driver behind me, Allows me to add this without having it look like I got it from KMART. Allows me to add it to my Harley Ultra WITHOUT splicing any wires, and is a very inexpensive upgrade.
Next week the last items I need will arrive by UPS.
There are two, 6 inch X 2 inch, ultra bright 20 led, red lense arrays, the perfect mounting plate that has holes already for these pieces and mounts directly to the factory license plate mount,l a 'Back Off', 'Wig-Wag' controller for 2 'separate brake lights', and a Harley 'trailer' wiring adapter that eliminates the 'splicing'.
The total will be slightly less than $100 when completed and I believe since I am NOT 'fooling around' with the 'turn signals' wiring then I don't have any fears of 'messing up' the turn signal flash rate or the HD security system.
If anyone is interested, I will be happy to provide 'details' when completed.
I have also ordered a dual 881 bulb 35 watt HID conversion for my 'stock' spotlights (which look very dim compared to my 6000K HID headlight).
Unfortunately, I ordered these because I couldn't find a 'ultra white' 881 bulb to replace my existing dim bulbs, nor could I find a 'replacement lens and bulb that was an H3 until I got my new J & P Cycles catalog (not affiliated with J & P Cycles).
They have a 4 1/2" lens with a an H3 bulb and there are many replacement bulbs on the market that are very, very bright.
They also have a bright 881 replacement bulb that is 'dirt cheap'.
Anyway, I only spent less than $80 for my dual HID spotight HID upgrade.
I may do the H3 upgrade until the winter when it is 'cooler' to work in the garage.
The new modules are dangerious in my opinion. Can't tell when the brakes ARE applied in the day time. Looks like the brakes are on all the time.
lp
