Chrome gauge bezel install question
Old 07-02-2009, 05:44 PM
Garemlin's Avatar
Garemlin
Garemlin is offline
Default Chrome gauge bezel install question
For those of you that installed the chrome bezels on the gauges of a batwing or shark nose. Did you use the supplied tape or did ya toss that in favor of something else like clear silicone.
Old 07-02-2009, 05:57 PM
Bad Pig's Avatar
Bad Pig
Bad Pig is offline
I tried the tape at first then got aggrevated because my sausage fingers couldn't get the "backing" off the tape....and the one gauge i did manage to use the tape for I wasn't comfortable with how it felt when I put it on.
solution? I used the clear silicone........a hell of alot easier!
I just put a small amount into the ring's channel and applied the ring....held a lil pressure on it for a min and WHOLA!!
just make sure you clean the surfaces first with a alcohol pad first and let dry.
silicone is also waterproof so no need to worry when they get wet
AttaGrl (04-09-2023)
Old 07-02-2009, 06:12 PM
hdrider07's Avatar
hdrider07
hdrider07 is offline
I used the supplied tape and have not had a problem with it so far knock on wood.
Old 07-02-2009, 07:32 PM
rocstar50's Avatar
rocstar50
rocstar50 is offline
I used the supplied tape in the first instance but the bezels would not stick. I think maybe it was too cold at the time. I removed it and used heavy duty double sided tape instead and it worked a treat.
Old 07-02-2009, 07:34 PM
dawg's Avatar
dawg
dawg is offline
Received 3,239 Likes on 1,850 Posts
I used the supplied tape as well. Worked fine for me.
Old 07-02-2009, 08:35 PM
wing_rdr's Avatar
wing_rdr
wing_rdr is offline
Used the supplied tape and cleaned it with alcohol swabs. No problems.
Old 07-02-2009, 08:39 PM
HarleyWood's Avatar
HarleyWood
HarleyWood is offline
I tossed the tape and used a little dab of silicone
Old 07-02-2009, 09:09 PM
stro1965's Avatar
stro1965
stro1965 is offline
3M double sided tape.
Old 07-03-2009, 05:12 AM
BillyG0856's Avatar
BillyG0856
BillyG0856 is offline
After reading pros & cons about the tape....I wiped the edges with an alchohol wipe, placed dabs of silicone around the rings, then placed on the gauges. When dried, I trimmed the silicone. Worked GREAT!!!
Took about 10 mins to do em all....
Billy G
Old 04-09-2023, 01:16 PM
AttaGrl's Avatar
AttaGrl
AttaGrl is offline
Stage II
Default Silicone
What brand/type of silicone did you use? My bezels didn’t come with tape so going the silicone route…
Quick Reply: Chrome gauge bezel install question
