MC Video Camera Recommendation ???
Anyone have a recommendation on what video camera type work on OK on motorcycles, in my case it is 05 RK Classic. I have a GPS unit with a RAM Mount on the handlebar, suspect I could get a similar mount for a camera. Seems like cameras are either cam corder type or the "bullet" type. I think the camcorder would mount behind the windscreen and the bullet camera I could mount on the engine guard. Any recommendations appreciated.
Rick
Rick
I mounted a little Memorex VidCam on a Ram Mount on the clutch housing. Problem is you get a lot of vibration through the bars. I am looking for one with the remote lens. I will try mounting that either on the Engine guard or on the side of my helmet. I can mount the control on the handle bar. There are a few advertised but I am still researching. Here is one.
http://www.goprocamera.com/
Use the most stable area to mount the camera. I used the touringpac plate, reverse view.
You'll have to try different areas to get the best video. Use a Maffer clamp ( used in film/video production ) It will clamp to handle bars. ( not good ) or crash bars ( better). Good luck. I once had the video recorded on a metric bike's handlebars, smooth video.... Just a thought!
Recommendation for MC Video Camera
This would be ideal. Too expensive, but it would be nice to find a cheap camera that has a remote controller/monitor as does this setup:
http://www.kustomsignals.com/product...pagename=video
RCA Small Wonder
Hey Rick,
I purchased an RCA Small Wonder Video Camera for less than $100 last year. I did not want to risk damaging an expensive camera. It records right on internal memory and easily downloads to your computer. It records in HD (720p I think).
I had a few extra ram mount clamps around so I picked up a bolt from the hardware store and mounted it to a ram mount using the tripod mount on the camera.
Not bad for around $100.
I have a few videos on you tube. Just search for MTBOTTLES1 and it will list them. They were all taken with the same camera and set-up. The one's from Lake George were from behind a windshield. The Ride To The Rally video had no windshield.
The difference is in the wind noise and at high speeds. The camera is flat and tends to shift when the wind hits without a windshield. The windshield will also prevent any damage to the camera lens from debris.
Whatever you do, most cameras have a hole for a tripod. Use that to attach to a ram mount. You can mount the camera anywhere you can put the ram mount.
GoPro looks reasonable, but it does not have a remote LCD. I wonder how it compares to something like the attached:
http://www.bhphotovideo.com/c/produc...specifications
