S/E Radio amp to install in 08 Ultra
Get you a wiring kit from HD
Advanced Audio High Output Sound System
When loud just isn't loud enough. The high output amplifier provides a 40-watt per channel boost to the Advanced Audio Sound System for distortion-free sound, even at freeway speeds. Amplifier is installed beneath the rigid mount Tour-PakŪ to save storage space.
76418-06A
Fits '06-later Touring models equipped with an Advanced Audio Radio and rigid mount Tour-PakŪ luggage system. Compatible with 2- and 4-speaker systems. Requires separate purchase of Wiring Harness P/N 70169-06
76418-06A
If you have the amp mentioned in the previous post, and you didn't get installation instructions for it, stop by an HD store and ask the parts guy to print out the instructions that come with the kit. It will also have a parts breakdown for the kit so you can check to see if there are any parts necessary for the installation that you don't already have, and you can order the missing parts if necessary.
The HD Service Manual for your bike should have instructions for installing the wiring harness, including outer fairing removal, gas tank removal for running the harness, etc.
Good luck with your project.
sportsterleroy
11-03-2008 07:31 AM
