Clutch lever play
Old 08-11-2009, 11:39 AM
todd-67's Avatar
todd-67
todd-67 is offline
Received 3,407 Likes on 1,593 Posts
Just adjust the cable. I have almost 4000 on mine and have had to do it a couple of times already.
Old 08-11-2009, 11:45 AM
mcouture's Avatar
mcouture
mcouture is offline
I can't adjust the cable any more. I'm assuming I need to either turn out the adjuster screw at the jam nut either more or less to get the 'clutch zone' where I want it but not having any luck...
Old 08-11-2009, 12:25 PM
mcouture's Avatar
mcouture
mcouture is offline
....well I just re-adjusted at the clutch adjuster nut. I turned it out only 1/2 of a turn and it's "better". It seems to be more in the "half way point" from the bar now.
What would make the clutch not be able to adjust like I want?
I could always adjust my Sporty's clutch exactly where I wanted but this bike seems to be different...
Old 08-11-2009, 12:35 PM
SoFla's Avatar
SoFla
SoFla is offline
Same issue here. Had it adjusted before the 1000 and at the 1000 (both at H-D)... now at 2700 it is sloppy again.
Can it be adjusted right at the lever?
Old 08-11-2009, 12:53 PM
nvsteve's Avatar
nvsteve
nvsteve is offline
It's cable stretch. Adjust it on the cable. It may take several times. There is not an adjustment at the lever.
Old 08-11-2009, 01:05 PM
TMART's Avatar
TMART
TMART is offline
I adjusted mine like Dawg said to do it.1/2 turn out at the clutch and a nickel width at the perch.Feels great!!!
Old 08-11-2009, 07:24 PM
voodoodrug's Avatar
voodoodrug
voodoodrug is offline
my clutch free play at the lever was randomly getting loose(way loose)then back to 1/8" normal play today. Any one have an idea?
07 ,adjusted clutch at derby once and it was fine at 10k now has 17k on board. Had to adjust cable twice over 17k but now its like got a mind of its own wtf
Old 08-11-2009, 08:02 PM
Neckball's Avatar
Neckball
Neckball is offline
If I don't tighten mine down to where it almost touches the perch, it rattles like crazy. I have to keep it tighter than recommended.
There is an anti-rattle clip, plastic half moon thing that is attached to the clutch lever inside the perch. You need to replace that to stop your rattle then adjust the cable to the proper spec.
Old 08-11-2009, 08:23 PM
Scooter68's Avatar
Scooter68
Scooter68 is offline
Originally Posted by Bikerdad61
Should just be able to adjust it at the cable. I did my '07 Ultra at 10,000 miles and it's been fine for the last 3K miles.
Did the same thing on my 04 just adjusted the cable and it's fine.
Old 08-11-2009, 08:31 PM
07fsxt's Avatar
07fsxt
07fsxt is offline
Makes a difference on mine if its hot or cold adjustment. A lot more play when hot
Quick Reply: Clutch lever play
