jiffy stand spring
Old 06-30-2009, 01:06 PM
huskers11's Avatar
huskers11
huskers11 is offline
thanks everyone. I got a new spring over lunch hour. I was planning on putting in on this evening, but the service tech put it on for free. That was very cool of him. The grand total came to $4.28
Old 06-30-2009, 01:30 PM
notlost_nc's Avatar
notlost_nc
notlost_nc is offline
I usually bend the spring and insert pennies into the open spaces, hold the spring up to the tabs and remove pennies. You're done.
Goldstar225 (01-20-2021)
Old 06-30-2009, 01:44 PM
kickstandkaddy's Avatar
kickstandkaddy
kickstandkaddy is offline
Collections Hold
I saw a spring come loose one time. Then I came up with this for safety
Old 06-30-2009, 05:11 PM
rjmac53's Avatar
rjmac53
rjmac53 is offline
great gizmo...
Old 06-30-2009, 05:35 PM
Sharknose's Avatar
Sharknose
Sharknose is offline
Originally Posted by huffhuff
easiest way to replace is to take the nut and locker off the top of the stand. remove the stand. hook the spring in the frame and the stand then angle the stand into the bracket and lever the stand right into the bracket. piece of cake. no tugging, pulling, cussing trying to install using pliers and such.
Bingo!
Old 06-30-2009, 06:48 PM
tincup64's Avatar
tincup64
tincup64 is offline
can anyone provide a part number (03 ultra) ??
thx - tin
Old 07-01-2009, 12:25 AM
dougbk's Avatar
dougbk
dougbk is offline
Originally Posted by bdp
+2, Thats cake with ice cream just as long as you have a way to support the bike while you are doing it. A wife, friend or even a jack will do the trick.
Lay it over on the engine guard. You won't scratch it so long as you don't let it slide back and forth while lowering it down or picking it up.
Old 07-01-2009, 02:43 AM
Arizona's Avatar
Arizona
Arizona is offline
Always carry a spare spring! I had that happen 2 or 3 times on my '05 EGC when I had it. The spring is $5 so keep a spare in your saddle bag. If you don't need it then someone in your group or someone you encounter on the road may need it and you'll be their HERO for sure.
I did it with my Leatherman tool - but you do need a helper to hold the bike up while you're installing the spring cuz it's easiest to do with the jiffy stand in the UP position.
Old 07-01-2009, 08:04 AM
skratch's Avatar
skratch
skratch is offline
Received 4,371 Likes on 2,543 Posts
yep, just like it says in the manual. guess them hd engineers do know what they are talking about.... always amazes me that guys will buy the manual and not use it.
Old 07-01-2009, 08:13 AM
frog13's Avatar
frog13
frog13 is offline
WHAT! There are manuals! Ok, I've got a couple but some of the pages are hard to read, damndest thing, if you use them they get dirty. So, does anyone know of a good way to clean the pages in my service manuals?
Quick Reply: jiffy stand spring
