Neutral light
06-28-2009, 06:24 PM
Neutral light
I just wanted to see if anyone has had this happen or may know a reason for it. When I ride in the mountains all of a sudden the neutral light and the red key alarm light comes on and stays on. This does ot happen at any other times only when I ride to in the mountains. I need to check when a Harley Mechanic but I thought I would ask here to.
Thanks AL
06-28-2009, 06:29 PM
My Neutral light is always on except in first. They changed the o-ring on the switch, they changed the shifter pawl. No dice, it's still on.
06-29-2009, 06:24 AM
It is a defective neutral switch...They are on the fourth or fifth revision. It seems to show up in the heat.
Replace it for $18 and five minutes of your time and it should be fixed. I did almost two years ago and it has been fine.
It's not the wire, it's not the o ring it is the switch.
06-29-2009, 06:48 AM
Neutral switch. Pretty easy to replace
06-29-2009, 10:13 AM
Thank You for the replies. Al
06-29-2009, 10:18 AM
They replaced mine.
It's still on.
dwe.61
39
11-27-2015 12:03 PM
monopearson
General Topics/Tech Tips
03-13-2012 08:40 PM
kingultra
05-24-2007 10:45 AM
Jimbo192
09-23-2006 07:22 PM
mradl2
08-06-2006 02:19 AM
