cam chain vs cam gear
ngoti8tor...in the newer ones 07 and newer in the touring line, they used an improved oil pump, a different cam plate and different type of chain and tensioners. which would not only require all the aforementioned if installing it on an 06 or earlier, but cams as well because the sprockets are different to match the new design chain. better off to just bite the bullet and go gear drive and forget about all the other crap to begin with. that's the information i've been able to decipher on the issue since the initial problem was discovered. i hope this helps you. but if it's for your 08 fatboy you're good to go with the drive system you've already got. it will last a long time with the improved system that the 07's and newer have.
Arizona
Exhaust System Topics
15
12-30-2006 01:58 PM
