motor mounts
motor mounts
how much space should the front motor mount have between the top side at the rubber and on the bottom where the big washer is..... mine seems to be vibrating too much and when looing at the mount with the bike running it doesn't seem to be doing its job...on the top side I have about a 1/16 or there abouts between the top bolt and rubber....underneath where the big washer on the bottom seems to be about a 1/2" and doesn't even touch the bottom part of the rubber when the bike is running ...I think this may be the cause of the vibration at idle speed...whatcha think??????
RE: motor mounts
they came out with a service bulletin on the touring front motor mount.they redisgned the mount and will replace yours.
http://eglide.org/forums/attachment....7&d=1148073305
Hogntheroad
07-28-2013 08:24 PM
