Tri-Bar Light Upgrade?
If you want to add a brake light function to the SG LED, you need to create a brake light circuit by splitting the run light wire into two wires; one for run light and a second for brake light.
Shown is the picture provided to me by Ride Time Technology. It shows wiring in diodes into both wires and a 30 ohm resistor into the run light wire. The wire on the right, though different in color, would be the run light wire from the SG LED. The one wire becomes two with the one with the resistor being the "new" run light; the other is the brake light.
http://
I removed my OEM circuit board/LED's from the SG light and replaced it with 90 LED's. The project is described with pictures in this thread:
https://www.hdforums.com/forum/touri...with-pics.html
http://
Last edited by Harleypingman; 06-28-2009 at 04:31 PM. Reason: Correct attribution of picture to RTT
One of the first mods I made. You can view a cheezy video I made last year and see the light in action. Little pain to install but worth it.
http://tinypic.com/player.php?v=i56m...=4&tag=upgrade
tully_mars
01-26-2011 08:50 PM
